Define the vendor option.
Perform this procedure to configure DHCP vendor option data global parameters.
The switch follows inheritance and precedence rules for configured DHCP Server options. For more information, see DHCP Server.
Configure the vendor option data:
Switch:1>enable Switch:1#config t Switch:1(config)#ip dhcp-server vendor-option-data 2 value 46 <cr>
The following table defines parameters for the ip dhcp-server vendor-option-data command.
Variable | Definition |
<1-255> |
Specifies the vendor ID. |
value WORD<0-128> |
Specifies a value to apply to this vendor option. |
